Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Downgrading 320 series from Win7 to Vista questions
I have been rummaging through the forums looking for previous posts matching what I'm about to try, however the ones I have found are older, and I don't want to assume they are uptodate with the latest software/update info.
My 80gig SSD 320 series has been on Windows 7, and running perfectly for a year now, but it has come time to upgrade to a 120gig, as I'm running low on room (dont get me started on the WinSxS folder). I am going to reinstall the 80 gig in my laptop, which has a Vista license.
I am not all that familiar with SSD's, but have built many computers. I plan on using the Migration Utility to the new drive, and expect no issues. My question(s) revolve more around the best way to approach going from Windows 7, to Vista.
1. What would be the best way to format/wipe the drive?
2. I understand there is no built in trim feature for Vista, so do I install the OS, then run the trim feature or ?
3. Any pitfalls or gotcha's I should be careful of?
Thanks!
Community Manager
Well, it's been 6 days since I posted this, and obviously.. no replies.
hmmm... There is a post at the top of the main SSD page that states "Intel DOES monitor the SSD.."
and herewith is a quote from that post:
The intent of the Intel SSD community is for Intel's SSD customers to exchange ideas, thoughts, experiences and questions concerning their SSD and to provide guidance and answers to others in a supportive environment. Intel monitors this community regularly and, on a selective basis, publically responds to posts. In other cases, Intel may respond to a post via a 'Private Message' which is an email sent directly to the poster.
Is there a period of time BEFORE Intel responds?
Community Manager
You have two options regarding "wiping" the drive. Either a secure erase via the Toolbox or other method (with the 120GB SSD installed with an OS on the Win 7 PS), or simply quick format the 80GB SSD and run the SSD Optimizer on it.
Although Vista does not provide the TRIM command, install the OS in AHCI mode, with the IRST F6 driver during installation, and the full IRST package after OS installation. Then use the Optimizer on the Vista PC, which hopefully has a SATA chipset that is supported by the Toolbox.
Contact Intel Support directly if you want their opinions, the main intent here is a user support forum.
Community Manager
Thanks for the info parsec.. I'll be doing the install after I can open my gift.
