cancel
Showing results for
Search instead for
Did you mean:
ERROR CONNECTION TO DRIVE
Esteemed Contributor III
I just installed a new X25M 80GB drive and installed Windows 7 64 bit. I downloaded the toolkit 1.2 so I can enable TRIM support. However, when I launch the software it says "Error connecting to Drive."?
Does anyone have any ideas how I can fix this.
1 REPLY 1
If your SSD connected to an Intel chipset on your motherboard, use the laest Intel RST 9.6 Driver. It has Trim support.
Download from here: /thread/11920?tstart=0 http://downloadcenter.intel.com/detail_desc.aspx?agr=N&ProductID=&DwnldID=15251
