Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Early 2011 13" MBP and 330 SSD compatibility issues
Recently my originally 500gb hdd failed and I finally decided I want the new 330 SSD as a replacement and think that intel might be a reliable replacement
Then I went on to install it
However the disc is not found in disc utility on the snow leopard install disc (yea Im still using snow leopard)
Worse still it says the SSD is not connected or disabled in firmware update
What could hv been the prob?
What else could I do to make it recognize the disc?
Tags (2)
