Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Error 26 in SSD Toolbox?
The SSD Optimizer encountered an error (26) when trying to optimize. What is error 26?
Tags (1)
ASouz7
Hello richardm1,
Have you tried to update the Intel® Solid-State Drive Toolbox to the latest version? Here you can find the link to it: https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Intel® Download Center
-What type of PC are you using? (laptop or desktop)
-What is your OS?
- How is the SSD connected this PC?
-Has this error occurred before?
Community Manager
  • It is a laptop on Windows 7 x64
  • The SSD is internal (SATA). It was just recently installed; this is the first time I have attempted to run SSD toolbox on this machine. It has never worked, even after a reboot.
  • The SSD used to be in a desktop machine and SSD toolbox ran OK on that system.
ASouz7
Hello richardm1,
Can you please provide the following?
1 - System make and model
2 - Firmware version of the SSD
3 - Details export from the Intel® Solid-State Drive Toolbox
4 - Copy of C:\intel\logs\intelSSDTDK.log
Community Manager
  • HP Elitebook 6930p
  • SSD Toolbox 3.2.3
  • Firmware 335u
  • The error in the log is [14:04:46:12] ERROR : .\Optimizer.cpp(225): Optimizer::Execute: Failed to set backup privilege
  • I am running the SSD toolbox as Administrator (right click, Run as Administrator).
Community Manager
Hi again,
My problem is solved. There was Group Policy in the domain that was modifying my system's user rights assignment (specifically the setting regarding backup privileges). I removed my machine from the domain and now the SSD Toolbox runs perfectly.
ASouz7
richardm1,
We are glad to know it has been resolved. let us know if you need any more assistance.
