Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Error: RAID array detected... Intel SSD Toolbox
I Just installed my new Intel SSD 520 Series 480GB Drive (SSDSC2CW480A310) and installed the Intel SSD ToolBox. When I run the SSD Optimizer I recieve the following Error: "Error: RAID array detected. If RAID array not present, reboot and try again". My system is as follows:
Lenovo 4270CTO BIOS: 8BET55WW (1.35 )
Intel(R) Core(TM) i7-2960XM CPU @ 2.70GHz
SSD: INTEL SSDSC2CW480A3 Firmware 400i
Intel(R) HD Graphics Family 3.76 GB
NVIDIA Quadro 2000M
Microsoft Windows 7 Professional (64-bit) SP1
32GB DDR3-SDRAM (1333 MHz)
I do not have a RAID configuration.
Thanks -
Tags (2)
Community Manager
Strange and then maybe not, laptops can have all kinds of odd SATA issues.
Actually, your issue is known to exist on another laptop, a Dell. That is documented in the Toobox Installation Guide, here:
http://downloadmirror.intel.com/18455/a08/Multi-Language_Installation_Guide.pdf http://downloadmirror.intel.com/18455/a08/Multi-Language_Installation_Guide.pdf
Have you asked Lenovo about this problem? Can you get into your laptops BIOS and see what the SATA configuration is? I assume you tried to reboot, but nothing changed?
Community Manager
add to the list an HP pvilion g7-1219wm. same thing happening with my series 320 120gb...
Community Manager
joe, Sorry to hear that. In other words, you cannot use the Toolbox functions usually available for a single SSD?
In case you don't know, the Toolbox does not offer its usually functions to SSDs in a RAID array, even if they are Intel SSDs. Simply having the SATA mode set to RAID does not cause this, since single (non-RAID array member) Intel SSDs will have all the Toolbox options available to them, they are basically operating in AHCI mode.
Whatever way the Toolbox determines a SSDs configuration, is apparently failing in your case, and for the OP too. Perhaps a protocol not being adhered to, or data missing or corrupted, is causing your issue. Not that you have done that.
If your SSD is connected to a SATA chipset other than an Intel, that usually causes the SSD to be undetected by the Toolbox.
Community Manager
thanks for the info parsec. my laptop has only one drive, and that's the ssd (well, it's also got a card reader and an external usb mechanical storage drive connected, but that shouldn't make a difference). this drive was formerly in a self-built desktop pc and had no difficulty, but the toolbox was an older version. this is occurring with ver 3.0.3 of the toolbox, so I may try an older version and see what happens.
Community Manager
ive the same problem. only ssd installed. set ahci in bios before installing win7. flashed bios with latest. bought programme to get all latest drivers. 3.1.1 toolbox. System is
asus m4a89gtd pro m/b
amd phenom 11 x4 965
4gb ram
win7 home edition 64bit
ati radeon hd 4800
intel 520 ssd 120gb
Asus tech could not help. tried everything i know.
Community Manager
I know for a fact, that these people are not having a problem on their part. I had the Asus chipset drivers installed, then i updated them with the NEW AMD chipset drivers for my chipset . Mine is set to AHCI in the bios and all was well, toolbox worked. As soon as i updated the drivers, rebooted the computer and tried the toolbox to run the optimizer, I got the message that i have an raid array which i do not have. I have an Intel 320 ssd. I know what i'm doing on computers so don't even go there. There is obviously a problem with the toolbox detecting raid , when it should not. Maybe you all at Intel should setup a computer with a AMD 850FX chipset and see what happens.
You will get the same result. Please let us know when you figure this out.
Thank you for listening .
Community Manager
So the Toolbox worked fine on your AMD system (not a given), but when you changed to the new AMD "chipset drivers" (inf files? SATA driver? not clear to me) the Toolbox then sees your single SSD as a RAID volume? That is a common error seen with the Toolbox.
Apparently the previous driver communicated fine with the Toolbox, but the new one doesn't. So who's bug is it, driver or Toolbox, chicken or egg?
Community Manager
Who cares Chicken or Egg, Intel Big Corp. You sell products. At least check into it, and quit making excuses.
If you don't have anyone there smart enough to figure it out, get someone who can.
Why is it that big companys always want to blame someone else instead of doing some investigating of their own?
Don't worry I also put it on an AMD forum too.
Hey I got an Idea! who cares if it all works or not , we got our money.
Intel 1 the Consumer little guy 0 again. Tell me is that why the Ivy bridge Processors run Hot?
Did we screw up and put the wrong compound on the processor? Did we fix that too? NOT.
For once give it a try Intel and see where the problem is.
Community Manager
I have the same issue, exact same motherboard, ASUS M4A89GTD PRO, AMD Phenom II X4 Processor, 12 GB Ram, Windows 7 Home Premium.
Intel 520 SSD 120GB Firmware Version 400i. When I check device manager it says INTEL SS DSC2CW 120A3 SATA Disk Device.
When I start the Intel SSD Optimizer I get "Error: RAID array detected. If RAID array not present, reboot and try again."
No amount of rebooting will help, I always get the same error, and I do not have a RAID configuration! I have two other Western Digital hard drives.
I paid more for the Intel SSD because I thought it would be more reliable than other SSD drives. Not sure about the others but the Intel SSD is not reliable. I still get the occasional computer freeze even after turning off power management features including the hard drive sleep to never etc.
Intel, please update your SSD Optimizer so it works!
Community Manager
Same here, suddenly happening on a previously smoothly working system.
The Problem is, that I DID NOT DO ANY CONFIGURATION on the system.
Probably since one week (the last Windows Update) the system first time ever became slow and jittery.
Then I want to run the Intel SSD Optimizer as a remedy, and it gave me the
Error: RAID array detected. If RAID array not present, reboot and try again. .
Absolutely strange. There is no raid whatsoever!
Any access to the SDD is slow, and Process Explorer shows "Interrupts and DPCs",
while atapi.sys (Intel 14.11.2003, v5.1.1.1001) uses time in the range of milliseconds (RATTV3)!
IBM Thinkpad T42p - Intel 82801DBM Ultra ATA
Intel 320 1.8" FW 4PC10362 , SMART OK, 1.5 GB free
Windows XP, sometimes ATAPI 9 Errors in System Event Log,
Besides, what I have done to exclude a hardware failure.
I exchanged the PATA to SATA Adapter in front of the SSD against another hardware piece, no change.
I re-installed the old, original HDD (with a one year old status of Windows XP) into the T42p,
and everything worked fine without any ATAPI 9 errors.
So it is either a slowly dying Intel 320 SSD or som sort of a bizzare Windows driver problem.
Any ideas?
Community Manager
In my case reported above, the source of the problem was, a MicroSoft "feature".
For some unknown reason it downgraded the SSD at IDE Port 0 to PIO MODE (from UDMA 5),
which caused it to become very slow ("Interrupts and DPCs" at 80-99% in Process Explorer, caused by atapi.sys).
In Windows XP Control Panel, System, Device Manager uninstalling the driver for the IDE Port 0
and rebooting twice, as adviced by the system, resolved the problem.
The SSD 320 is now in UDMA 5 again, performace as before, and Intel SSD Toolbox is not complaining
about a non-exising RAID: what a poor software!
see
http://support.microsoft.com/kb/817472/en-us IDE ATA and ATAPI disks use PIO mode after multiple time-out or CRC errors occur
Hopefully the Intel 320 is not dying slowly...
Community Manager
So you are using a SATA to PATA adapter, which must change so many things, including protocol, and who knows how good a job it does, and to even what SATA standard it supports, and is stuck running in UDMA5. Then the Toolbox software must try to communicate with the SSD through that old interface, and then through the SATA to PATA adapter. It's a miracle the Toolbox can function at all!
But you call it "what a poor software!"? All it takes is one bit to be not correct in the data identifying the SATA mode for the Toolbox or any software that reads that data, for the result to be wrong. But not only is this not a SATA interface, or IDE, but PATA, and then not even that, PIO! As the old saying about computers goes, garbage in, garbage out.
Hopefully your SATA to PATA adapter is not killing your SSD.
Community Manager
@parsec: This is just FUD!
a)
This "raid error" happend also to ohters, who have no adapters, nor raid installed.
b)
The HW combination with SATA-PATA-adapter, was working for a year, nearly 24x7.
It passed all HW Tests, and the Toolbox itself did not indicate even one error,
nor compained about adapters.
For now, I exchanged every bit of hardware (the laptop, the adapter) around the Intel 320 SSD, and errors only occur with this very Intel 320, and everything is fine with other HDDs or SSDs, or binary compatible laptops.
Also Kubuntu 8.04 stated to report, "ata.01 Emask 0x0 ... frozen" errors.
As far as I got with this SSD, it seems, it has a loose contact, which manifests itself whenever the SSD has cooled down to room tempreature over night, and then is rebootet. If it is at working temperature errors only rarely occur. It is also failing with a direct SATA connection in a Win7 machine.
c)
If this PATA/SATA business should be so important, as you write, then the INTEL SSD Toolbox should cope with it. Additionally a quality SSD by Intel should also cope with an adapter. Aggravating, because of the lack of a bootable image running the SSD Toolbox from USB pen drive, one cannot easily test the Intel SSD with the Toolbox.
Community Manager
I'm getting this exact same error and I have no RAID setup.
I installed my SSD 520 last week and ran the SSD Optimizer and it ran fine. Now it is a week later and I went to run it again and I'm getting this error. I haven't added anything to my system in the last week. What do I do now? I've got half a mind to return this drive and go with another brand. Intel needs to fix this. ASAP.
A good work around would be an override button to run it anyway even if the stupid software thinks it detects the non-existent RAID. I've rebooted 3 or 4 times already. I've double and triple checked that my BIOS has my drives set to AHCI. I'm running Windows 8 Professional. I'm seriously disappointing in the poor quality of the Intel software, I regret my purchase, and I am heading to Amazon (where I bought it) to write a one star review now.
How long can I expect this drive to last if I am unable to run the optimization?
--Eric
Community Manager
OK I figured out how to get it to run. I spent hours on this. Windows said all my drivers were up to date, but I backed them all up then I was going one by one uninstalling them and letting windows reinstall it. When I got to the "AMD SATA driver" after the uninstall and reboot, windows replaced it with the microsoft "standard SATA driver". All of the sudden the intel optimization tool works. This is a serious bug in the intel toolbox, because I'm sure the AMD SATA driver wasn't reporting that a RAID system was in operation when it wasn't.
If you have a motherboard that comes with the AMD SATA driver, uninstall it, delete it, and let windows install the standard microsoft SATA driver and this problem will go away.
This shows very poor quality control on intel's part. This problem was first reported here a year ago and has not been fixed yet.
Community Manager
Thanks very much!!!! Your fix worked for me. I uninstalled the driver (Control Panel > Device Manager > IDE ATA/ATAPI controllers >AMD SATA Controller > Driver > Uninstall).
Windows 7 restarted a couple of times and now the driver has been replaced by the Windows Standard AHCI Serial ATA Controller.
Hope this solves my computer freezing which happens frequently when it has been left unattended for a few hours (a problem which I never had before I got the SSD drive.).
Community Manager
@ Eric ...
Thank you! I've been looking for a solution for the RAID array error for several days.
I recently installed two series 320 SSds on my custom-built desktop: a 120GB SSDSA2CW120G3K5 as my boot drive, and a 160GB SSDSA2BW160G3L as my data drive. I have an MSI 785GM-E65 (MS-7596) motherboard with 16GB RAM, AMI BIOS v2.12 set for AHCI, running Win7 Pro SP1.
For whatever reason, the Intel SSD Toolbox (3.1.2) would optimize the 160GB drive, but return the RAID array error, even though no RAID array was present, on the 120GB drive. Your fix solved the problem.
Community Manager
Eric; another thanks to you.
But, while the install of the MS driver lets me use the Toolbox Optimizer it created another problem, random slow boots, instead of 15secs they would drag on for over a minute with a blank screen showing and the disk light on, and random system freezes for a minute or two. I reverted back to the AMD driver and my system is solid again.
I'm wondering about the need to run the Optimizer in the first place. I've gotten the impression that the Toolbox Optimizer runs the Trim command on the drive, but Win 7 runs the Trim command also, on what basis I don't know. Maybe the Optimizer is intended for other OSs that don't have Trim built in.
I'm going to start researching that now.
My system; HP P6620f.
Community Manager
I am getting the same error message, and tried to uninstall the driver but it ended same way. I don't know what to do nor where to find answers.
Community Manager
Laurence, Let us know what you find out. My system regularly freezes and the HDD light goes crazy for about 15 seconds and all the programs stop responding. Then after 15-20 seconds it just starts responding again.
