cancel
Showing results for
Search instead for
Did you mean:
Extremely slow 4k write on X25-M 80 GB
Esteemed Contributor III
Hey,
I installed Windows 7 on my SSD 2 days ago and now I ran benchmark and it gives me the next results:
Read values seem to be fine (well, 4k is slow) but the write values are kinda horrible. Especially 4k which is like superslow. My drive is from the second generation (2G) and I started using it 2 days ago so it really can't be too worn either. My machine is Lenovo T400 and I don't really see any reason for the slow write speeds. I really need some help with this thing, what should I try / do next?
1 REPLY 1
Got this fixed, in some ssd-guides they were referring to keep write caching off but that's most likely bs and was causing the slowness.
