Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
FW tool does not discover installed SSD
I just wanted to flash my 80 Gig Postville SSD but after booting the flash tool from CD it says it can't find any Intel SSD in my System.
The weird thing is I am running Windows 7 perfectly fine on this SSD and it defintely works in my system.
I am runing it on SATA Port 0 on my Asus P5B Deluxe mainboard attached a JMicron controller.
BIOS is set to AHCI for the SSD and the controller.
Does anyone have an idea what might be the problem here?
Thanks in advance!
Community Manager
Hi, I have the same motherboard. I had to switch to the IDE mode before it detected my SSD.
Remember to switch it back to AHCI after updating.
BTW, the latest firmware screwed my SSD, so be careful!
Community Manager
Thanks for the hint.
Waht does screwed up mean - could you explain that more detailed.
What happened exactly?
Community Manager
