Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Firmware Update 02M3, Install Problem
Jump to solution
When booting to the ISO image on DVD, I get the following error message:
"Bad or missing command interpreter" & "Enter the full shell command line"
The workstation is a Dell Precision 3500 running Windows 7 Pro 64 bit with a X25-M 80GB boot drive. FWIW...I have applied firmware updates in the past without issue.
Community Manager
Sorry folks...this was completely user error on my part. Once I changed by BIOS RAID settings to "RAID Autodetect/ATA", the firmware update ran without issue. This was mentioned in the PDF Update Guidelines...I just skimmed past the "Known Issues" section, as I had applied firmware updates in the past without any BIOS changes. I'll be more careful next time.
Community Manager
Community Manager
It's a common mistake... I did the same thing.
Community Manager
Thanks! This solved my issue and saved me hours of poking around.
