Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Firmware Update 2CV102M3 Results
I have 2 X-25M 80gb in Intel RAID 0. Here are before and after results for the 102M3 firmware update:
Before:
After:
No significant difference, as far as I can tell.
I'm running Win7 64 and this comment from the update readme file did not happen:
Note: For computers booting into Windows 7 after a firmware update,
a message appears when the operating system starts that prompts
you to restart the computer. Restart when prompted.
FYI
Ken
mmokk
New Contributor II
that message is from windows redetecting the ssd due to the firmware update. but since you're running the drives in an array, windows won't see that they've changed.
Community Manager
Good point.....Thanks
Community Manager
I saw virtually no difference in performance:
MSI main board
980X 4.3GHz
12Gb Corsair Dominator 2000
Community Manager
Well, it's not a given that this firmware update will increase performance as measured by 'Crystal or other benchmarking tools. For example, the update could be fixes or enhancements to wear-leveling, responses to TRIM commands, or bug fixes in the controller code that most of us would not understand without some education.
This is what Intel included in the Release Notes for the 2CV102M3 Firmware update:
This firmware revision fixes enumeration and slow-boot issues on SATA 6Gb/s controllers, adds improvements to S.M.A.R.T. attributes for more accurate reporting of drive health, improves NCQ capability, and fixes possible drive hangs when reading S.M.A.R.T. self-test log.
Nothing that is directlyly performance related, except for NCQ capability, which only comes into play with SSDs when the latency of other parts of the PC causes the SSD to wait for them. Perhaps they aren't mentioning everything, but they didn't mention enhancing the "user experience". Oh well...
Community Manager
Ok, first time I've done a firmware update on any of my Intel SSDs. Worked fine, easy, worked on my PC in AHCI mode. It was a newer, unused 80GB G2, going from 02HD to 02M3. I put a few files (jpg) on it just to see if they would be cleared or damaged, they were preserved and just fine. Here are before and after benchmarks:
Although the differences are small, and my SSD is an 80GB vs redux' 160 GB, I'll compare them anyway.
I lost a little in both sequential read and write speeds, while redux gained a bit in each.
Redux lost a little more than I did in 4k read and write, and while mine both diminished, my read speed was barely touch.
In 4k with 64 threads, we both increased a decent amount in read speed, and just a touch increase in write.
Our read and write access times are the opposite of each other, redux writes are faster than the reads, mine vice versa. My new read access time is pretty good, even if I lost 0.003ms.
If we can accept these results at face value, I traded some sequential read and write performance, and some 4k write performance for a relatively large gain in 4k 64 thread (NCQ depth) read speed. Given that NCQ was developed for HDDs to reduce head movement and latency due to their functional realities, while those issues are non-existent in SSDs, I must ask what is the point in optimizing this in SSDs?
I've read that SSDs use NCQ to keep busy while they wait for other systems of a PC that are to busy to accept data the SSD is ready to send to them. So with modern CPUs and DRAM memory, this still occurs? I really don't know, but that would surprise me if true. I'm just questioning and trying to learn.
Community Manager
NCQ in an Intel SSD enables concurrency in the drive so that up to 32 commands can be executed in parallel.
One of the revisions listed for with the f/w is improved NCQ capability, which is why 4K/64 performance has improved.
Community Manager
Yes redux, I wasn't seeing it in that way. I'm aware that the NCQ enhancement is the major performance upgrade in this update. Not that this will impress the sequential R/W speed demons, but I don't care. Seeing how those specs dominate most SSD marketing, to sell to the less informed consumer, I'm pleased to see Intel is not going in that direction. OTOH, the specs of the new 510 SSD do seem to be going in that direction. I can understand doing that, but it's a shame they feel they need to do so, if that is the case.
Community Manager
Retiredfields, those are some amazing numbers, most of them nearly exactly twice that of a single 80GB G2 Intel SSD. I see you are using iaStor, so I imagine your mother board has an ICH10R chip. Do you do anything to your SSD to compensate for the lack of TRIM due to RAID? Do you have an OS on your RAID setup? If so, was it compromised by the update, or was it untouched?
Although you aren't seeing increases (actually, slight decreases) in some of the standard SSD performance specs, like sequential read and write speeds, Intel's SSD performance philosophy is to tune for real world performance enhancement. The ability to perform multiple simultaneous I/O requests via NCQ at a greater rate then before with this update is more tuning for enhanced real world use. Although it is more difficult to relate to or appreciate increased speed with multiply queued commands vs sequential speeds, the former will actually be of more benefit to a user, IMO. We need to train ourselves to see beyond the simple "drag race" numbers and appreciate the complexities of these devices.
Community Manager
Yes, ICH10 on an EVGA X58 motherboard.
I posted this http://communities.intel.com/thread/14568 http://communities.intel.com/thread/14568 about my work around for no TRIM. Still seems to be working fine. I also leave about 1/3 of the array unallocated to give the drive firmware plenty of room to perform its cleanup.
I am using Win7 64 and there was no problem doing the firmware update. Changed BIOS to IDE legacy mode, did the update on each drive, and then changed back to RAID mode. I did have a current image backup, just in case......
Community Manager
Retiredfields, it sure did work, with your RAID 0 write speed being exactly twice the typical 78 - 80 MB/s single 80GB G2 SSD write speed, after your free space consolidation. Of course, we could ask if the cost of the rewriting using Perfect Disk 11 is more than that if TRIM was available, or if the Toolbox Optimizer could have been used. Even if it is overall, I'd say it's a moot point given the longevity of the NAND chips that Intel uses. You could check the SMART attributes and see what your Host Writes and wear indicator are showing, but I doubt it makes any real difference.
I'm not a RAID user so I don't know if NCQ is functioning on 'drives or volumes in a RAID array. It seems that it must be, although your 4k - 64 Thread read spec is less than twice my single 80GB G2, but not by that much, and the same with the 4k - 64 writes. It's interesting that your write access time is less than the read access time, which was the case with another forum members 160GB G2 SSD, while my single 80GB G2 has faster read than write access speed.
I also wonder how the benchmarking tools can measure speeds that are greater than the SATA 2 interface speed, generally specified as 300MB/s maximum. I'm not saying they are false or inaccurate, I don't know either way, I'm just curious. Wait, what am I saying, it must be that the tool "sees" the RAID 0 volume physically connected via two cables as one 'drive/volume. Is that the case?
I was wondering if the data on the SSD after the firmware update was always corrupted, as Intel recommends (seems more like a warning) having an image back-up done before the FW update. Now wouldn't it be nice if there was a stand-alone version of the Intel SSD Toolbox Optimizer program, that was part of an .iso file like the FW update utility, that could be run on RAID arrayed SSDs that were set to IDE mode for the optimization, just like the FW update. Your Perfect Disk method seems to make that unnecessary.
Community Manager
Before
After ,NCQ is looking better
Community Manager
CarrotThree, do you have a RAID setup of SSD's, or what? A bit unusual that you did not loose any sequential read speed after the update, and actually increased! We do see the apparently common loss of 4k write speeds, and the great gain in 4k NCQ read speeds. Are you pleased with the overall results?
Community Manager
Parsec , it is a raid 0 made of two 80GB X25-M ssd ,and yes i am happy with the update with the improved NCQ .
I already whas happy with one ssd and old firmware , but it is easy to make them in a raid configuration and have higher speeds.
It is done on with XP32bit ,asus p5Q ,E4800
Community Manager
Just wanted to post that on none of the systems I manage did ACHI work. I had to set to IDE mode to update the firmware. We use primarily HP Elite Desktop SFF 8100's, HP Business laptop 2540p's(laptop).
Community Manager
In my case, I have an ASUS SaberTooth X58 mother board, using the Intel RST iaStor driver, connected to the Intel ICH10R SATA 2 ports, with Windows 7 64 bit. I decided to experiment with the update, and left it in AHCI mode.
Your experience, mjm, is not unusual, it seems most users must change to IDE or legacy/compatibility mode.
Apparently, my overall configuration was just right to allow the update to occur in AHCI mode.
Community Manager
"Your experience, mjm, is not unusual, it seems most users must change to IDE or legacy/compatibility mode."
Intel should probably reflect this in the release notes, then. I don't recall having to do this for the last firmware update, and only one Lenovo system is noted in the guidelines known issues.
Community Manager
Yes that would have been nice to have in the Release Notes, but it does mention it in the Read Me file that is available on the same page as the Release Notes. It is also mentioned in the Guidelines file, although not very well IMO.
Intel apparently intends the Release Notes to simply contain what the update accomplishes and what products it is applicable to. As we can see in your experience, which is not uncommon, that you missed the necessity to change to IDE mode in some cases. That should be much more prominently displayed in the Guidelines and the Read Me documentation.
I agree it should be written to catch the readers attention more obviously, which would save the users and Intel some grief.
Message was edited by: parsec
