Community
cancel
Showing results for
Search instead for
Did you mean:
MB23
Firmware Update Tool won't find my 60GB 520's
Firmware Update Tool v1.93
2 x EKCV315402D5060GN - 60GB 520 Series - FW:400i
Tried by plugging into SATA ports of a number of M/Boards, including Intel DQ77MK and DH67GD and DG45ID.
In each case, I tried both AHCI and IDE modes in the BIOS.
In each case, the M/Board can identify the drives no problems, and I can use the drives with the O/S.
However, the firmware update tool says there are no Intel SSD attached, and doesn't allow me to do anything.
Jose_H_Intel1
Thank you for posting,
I understand you are trying to update the firmware on the Intel® SSD 520 Series.
Please note the Intel® SSD 520 Series already has the latest firmware; therefore, there is no need to update it. You may verify the firmware update is available for other models using the following link (and the first models list):
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363
You mentioned the drives are properly recognized by the motherboard and operating system. Just in order to make sure the drives are working correctly you may run a diagnostic test with the Intel® SSD Toolbox:
http://www.intel.com/support/go/ssdtoolbox/index.htm http://www.intel.com/support/go/ssdtoolbox/index.htm
