Has anyone been able to download and activate firmware to a D3600 via NVMe API calls? My code seems to work but the firmware never actually hits the slot... and no update occurs.
Is there a developer's guide available for this drive that details what is and is not supported?
Thanks!
Hello nvme_dev,
We understand you would like to update the firmware on your SSD DC D3600 via NVMe* API. We would like to know first:
-What is the current firmware of your drive?
-What is the operating system you have installed?
-Have you tried our supported CLI tool for the firmware update?
In case you need it, here is the https://downloadcenter.intel.com/download/26970/Intel-SSD-Data-Center-Tool?product=87278 Intel® Data Center Tool, which contains the latest firmware version.
For you to run the firmware, the command is isdct.exe load -intelssd "x" (Where "x" is the index of the drive).
If you need more information about our supported tool, https://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/ssd-software/Intel_SSD_... here is the guide.
We strongly suggest to you to use our tool to get the drive updated.
Nestor C
Hello nvme_dev,
Nestor C
Thanks, Nestor. I'm aware of the tool and it works nicely, but the idea was to script the upgrade via direct NVMe calls instead. I've got a response from Intel Engineering, and we'll take it from there.
Again, I appreciate the help!
