cancel
Showing results for
Search instead for
Did you mean:
Firmware update now available - Addresses Bad Context 13x Error
Alan_F_Intel
New Contributor III
New Contributor III
Status:
Intel has posted a firmware update for the Intel® SSD 320 Series (firmware 4PC10362) which addresses the Bad Context 13x Error being discussed on the Communities site and elsewhere. You can download the new firmware here:
http://www.intel.com/go/ssdfirmware www.intel.com/go/ssdfirmware
Also posted at this link are Read Me, Release Notes, and SSD Firmware Update Tool Guidelines which provide detailed firmware update instructions and other relevant information such as the most current firmware revision available.
What should I do if I have not experienced this issue?
In order to provide the best user experience, Intel always recommends users download and install the latest firmware. As with any storage device, Intel recommends users frequently back up their data and periodically check for firmware updates. The http://www.intel.com/go/ssdtoolbox Intel® SSD Toolbox provides a host of utilities to monitor your SSD, including displaying detailed information such as the currently installed firmware revision.
What should I do if I have already experienced this issue?
If you have already experienced a drive failure or encounter this problem before the firmware update was released, please contact your Intel representative or Intel customer support (via web: http://www.intel.com/ www.intel.com or phone: http://www.intel.com/p/en_US/support/contact/phone www.intel.com/p/en_US/support/contact/phone) for an SSD replacement. An alternative option is to use the Intel ® SSD Toolbox or similar tools to perform a secure erase in order to restore the SSD to an operational state; all data will be erased. After secure erase, update your SSD with the new firmware. The firmware update will not recover user data.
Background:
For users unfamiliar with the issue, an Intel SSD 320 Series drive may exhibit a drive capacity of 8MB and an electronic serial # field containing a message of "BAD_CTX 0000013x" caused by an unexpected power loss under specific conditions. Once this error occurs, no data on the SSD can be accessed and the user cannot write to or read from the SSD.
rgds,
Alan
NVM Solutions Group
94 REPLIES 94
JG1
New Contributor
Since this is FreeDos, can I boot with a system that has 8GB ram installed?
Esteemed Contributor III
What's the point? 8GB ram or 800 FREEDOS don't care . It will use only as much as needed.There is no maximum requirements, only minimal.
Anyway I have absolutely no problems running freedos with 16GB RAM installed.
Will there be a separate update for OEM versions of the SSD 320 or do we have to contact our OEM after some period of time? I was frustrated to find that the firmware update utility wouldn't run on my Lenovo / Intel SSD because it said the firmware version on the SSD already had the fix.
Thank you very much, Intel. Even in 2011 we have to use DOS, CDROMS and switch to IDE in BIOS to flash your SSDs. That is SO tommorow.
Don't you know, DOS will never die, in this case it must be some old fart at intel who still uses floppies and 5 1/4 drives romancing the good ol' days where 12M drives were the size of a printer.
Don't know why he is still on the payroll...
