Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
First time - is this all there is to do?
My first SSD will be here in a couple days and just want to make sure I have everything lined up. I've been reading up on what you need to do to get it working, is this it? Did I miss anything?
From the Intel SSD user guide:
Verify scheduled Defrag is turned off.
Disable Superfetch
Make sure you have the proper drivers installed - Intel Rapid Storage Technology V 9.6?
From else where I read:
Set the bios to AHCI mode when installing Windows
Use the latest Intel RST drivers
Run the optimization tool from the Intel SSD toolbox
Do I need the Toolbox?
What I have:
Intel X25-M Mainstream SSDSA2MH080G2R5 80Gig
Custom computer
Windows 7 Pro 32 bit
Gigabyte MB
Intel Quad Q8400
4G memory
Thanks for any help.
Will
Community Manager
Anybody......... anybody......? Bueller?
Community Manager
It seems you got everything covered...
Community Manager
Seems right to me. I just completed mine and went REALLY quick. Just be sure your SSD has the lastest firmware update which recently came out. You can get it here.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Solid+State+Drives+and+Cach... http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Solid+State+Drives+and+Cach...
Good Luck
Community Manager
Cool thanks.
Am I missing something I downloaded the Toolbox and the firmware, where is the driver? It wasn't in the list of downloads. Isn't there a Rapid Storage driver?
Will
JAMES_J_Intel
You can also take advantage of the Intel Data Migration Software available at; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3114&DwnldID=19324&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3114&DwnldID=19324&lang=eng . This will make the cloning of your existing HDD to your new SSD much easier.
