Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Four Intel X- 25 M 80 GB Raid 0 performance
Hello, I am new to intel forums and looking for some information.I just finished installing latest firmware and Windows Ultimate 64 bit along with all drivers. I ran a bench for my RAID 0 performance and something does not add up right. I should be getting over 800 mb read but I am not getting those type of numbers. To bench my raid I used HD Tune Pro 4.60 and these are the results.
Minimum = 555.4 MB/s
Maximum = 697.3 MB/s
Average = 621.0 MB/s
Access Time = 0.082 ms
Burst Rate = 5662.9 MB/s
CPU usage = 3.0 %
System Specs
I7 950 Bloomfield D0 @ 4.21
EVGA 4 Way Classified Bios.82
Corsair Ram CMT6GX3M3A2000C8 12 GB total @ 8-9-8-24-88 2T 2000 mhz
Corsair AX 1200 PSU
EVGA GTX 570 HD 3x
Sound Blaster X-Fi fatality pci-e
Intel X -25 M 80 GB 4x in Raid 0 mode
Cpu is water cooled along with my motherboards NB,SB and Mosfet. Not sure what could be the bottleneck
Tags (1)
Community Manager
The ICH10R peaks at aroun 650-750MB/s sequential reads so the RAID controller is the bottleneck. You might be able to squeeze higher synthenic numbers if you use deeper queue depths and large fliles.
However, this is actually great for an onboard controller. If you want more sequential throughput, you will need to invest in a discrete hardware RAID controller ($150+).
Community Manager
Why do you think you should be seeing over 800 MB/s read speeds? What is that figure based on or how is it calculated?
Community Manager
Probably 250MB/s sequential read for each drive times 4... then minus some for imperfect scaling.
Community Manager
Hi Duckie, Yes, that is one obvious but IMO rather simplistic method of determining what the result "should" be. Things are rarely that simple and the entire system must be taken into account. As you mentioned, there is a limit to what the SATA controller can provide. I've never seen the figure you mentioned in any of the ICH10 documents, I'm not questioning it and might have missed it. I wonder if differences in the RAID driver and its settings would make any difference.
Community Manager
Hello and thank you for the replies, I am using the most recent updated drivers for ICH10 raid controller and only option I have toggled is
Write Back Cache : Enabled in my Intel Rapid Storage Technology application. Is there any other setting I should look in to ?
Here is a screenshot of HD Tune Pro stats.
Intel X25-M SSDSA2MH080G2K5 2.5" 80GB SATA II MLC Internal Solid State Drive ( 4X )Sequential Access - Read up to 250 Mb/s on each driveForgot to mention I am also using latest firmware for each ssd drive. On a side note which raid controller would you recommend ?
Community Manager
Parsec, I am not sure if Intel prints the peak bandwidth of the ICH10R anywhere. However, I have seen that 600-700MB/s bottleneck occur on multiple benchmarks over the years.
Certified, I can really make direct recommendations. However, you would be looking at server hardware RAID controllers with dedicated RAM and CPU. The newer models specifically have support for SSDs. Note that RAID0 provides sequential performance gains.for the most part. Your random performance is probably about the same. Unless you have specific workloads that do large (1GB+) sequential read/writes, the benefit is questionable.
