cancel
Showing results for
Search instead for
Did you mean:
Freedos fails to start updater..
Esteemed Contributor III
Everytime I try to start the firmware update for my 2x 80 GB x25-M SSD's (INTEL SSDSA2M080G2GN) an error occur.
INITDISKBAD command.com /p /e :256
FreeDos loads and I see it executing -INITDISK... but after a few seconds it shows the massage like above.
I have my ssd's in IDE SATA MODE in the BIOS just like the manual says.
Can anyone plz tell me what i'm doing wrong?
3 REPLIES 3
Hi!
Have you solved this?
I have the same problem. The cd works fine and boots i other computers. But my computer where the ssd is, gives exactly the same error as yours.
Thanks!
Magnus
Well i did a workaround.
I used an other pc to update the firmware.
I see! Alright.. Thanks!
