Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
From SRT to SSD
Hi all
I bought a 520 Series SSD (120GB) and wanted to use this as my primary boot drive. I don't want to do a fresh install simply because I don't want to go through the arduous process. Is it possible for me to clone my current HDD to this new drive as well as pick and choose which programs I want to port over? Is this something I can easily do given I've enable SRT from the beginning?
VLM
Current Setup:
i5 3570K (clocked @ 4.3 GHz)
Asus Sabertooth Z77
Crucial M4 SSD, 64GB (dedicated to Intel SRT)
1 TB WD Caviar Black
Crosair Vengeance 16 GB @ 1866
Intel 520 SSD, 120GB (new uninstalled)
JAMES_J_Intel
You can use the free Intel Data Migration Software to clone your existing HDD; http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3337&DwnldID=19324&ProductFamily=Solid... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3337&DwnldID=19324&ProductFamily=Solid...
You will have to image all your files and afterwards delete those that you do not want.
Jim
