Community
cancel
Showing results for
Search instead for
Did you mean:
badstink
Full Diagnostic Scan always fails during Read Scan on my SSD 600p Series 256GB
I have an Intel SSD 600p Series 256GB. I installed the Intel Solid-State Drive Toolbox software on my computer to help look for possible drive problems.
(I am unable to back up my C: drive to Synology DiskStation using their Active Backup for Business software. Synology support team says the error logs indicate it's due to hard drive errors.)
SMART Summary shows perfect Drive Health and estimated life remaining is above 90%. Firmware version is PSF121C. Quick Diagnostic Scan works perfectly. But the Full Diagnostic Scan fails every time on Read Scan at 0%. The error given is "Error: An error was detected reading data from the selected Intel SSD. Contact your reseller or local Intel representative for assistance."
The only issues I've had are that I cannot back up the hard drive to Synology and the Toolbox's Full Diagnostic Scan does not complete successfully.
How can I resolve these two issues?
n_scott_pearson
Super User Retired Employee
S.M.A.R.T. can predict certain kinds of drive failures, but there are many other types that it won't catch. In your case, you've seen two different reports of problems with the drive yet you seem to want to discard them because S.M.A.R.T. isn't predicting anything. Worse, this toolbox app is assigning a life remaining number, which isn't worth the paper its written on, and this only confuses the matter.
In this particular case, you have read operations failing - which is an indication of damage or corruption in a portion of the drive. I would replace it immediately.
badstink
I've never had to request support with Intel warranty before. Hopefully it's a painless process.
Santiago_A_Intel
Thank you for posting in the Intel® SSD community on your request for support for your Intel® SSD 600p Series (256GB, M.2 80mm PCIe 3.0 x4, 3D1, TLC).
We would like to thank our community members for their cooperation on your inquiry.
The SMART logs provided have been analyzed, and as indicated, it reports, your drive is in perfect health; we’ve noticed your concern on the Toolbox report, after a Full Diagnostic Scan, that reported a READ Scan error; this is usually fixed by performing a Low-Level format; please make sure your data is duly backed up prior to initiate the format procedure; to do this, find below, instructions on When to Run a Low-Level Format or Secure Erase on Intel® Solid State Drives and Tools to Use. Open Link here: https://www.intel.com/content/www/us/en/support/articles/000006198/memory-and-storage.html
In addition to this, we are requiring with your cooperation to provide us with some information about your system, where the SSD is attached to. To do this, Intel® has available, the Intel® System Support Utility for Windows*; you’ll be able to download it on the following link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
·        Please download the software.
·        When finished downloading it, open it and follow instructions
·        Please attach the SSU Log text file obtained on your next your reply.
We will be looking forward to your reply.
Santiago A.
A Contingent Worker at Intel
badstink
SSU Log is attached.
badstink
I attempted to use Acronis Drive Cleanser software. The first step in that software application attempts to detect my drives. It gave a popup that says "This product edition requires at least one Intel SSD drive to be installed in your system. You can upgrade to the latest unrestricted version of Acronis True Image at http://www.acronis.com/promo/intelssd/." and the Continue button is greyed out and cannot be selected. I am unable to perform low level format using that software.
badstink
I am unable to perform Secure Erase using the Intel SSD Toolbox because the C: drive I wish to format contains my OS and it is my boot drive. The instructions in Secure Erase indicate that this operation cannot run on boot drives or drives with a partition.
badstink
Are there any Intel products that can be used to fix this issue? It seems none of the ones you have suggested will work.
Do I need to use a 3rd party product instead?
Santiago_A_Intel
Thank you for your reply.
We have received the SSU Logs
Please let us know the results, after performing the Low-Level Format procedure as recommended previously.
Always back up your software before you run a low-level format or secure erase.
You just need to follow the indications on the article recommended. Open Link for details: https://www.intel.com/content/www/us/en/support/articles/000006198/memory-and-storage.html we recommend any or the 3rd party tools as indicated in the article.
Have a nice day;
Santiago A.
badstink
In support article 000006198 that you linked above, the instructions state:
"Several Intel® tools have the capability to perform a low-level format or secure erase. Some recommendations are located at the following support page along with how-to instructions: Three Ways To Run Low-Level Format Using Intel® Software Tools."
As I mentioned earlier, all 3 of the methods listed the "Three Ways to Run Low-Level Format Using Intel Software Tools" document do not work for me and here are the reasons:
Method 1: The Secure Erase option doesn't work because my SSD drive is partitioned and is a bootable OS drive.
Method 2: The Intel Data Management's Active Drive Cleanser option doesn't work because it doesn't recognize my SSD as an Intel SSD. It wants me to upgrade to a non-free version of Acronis True software.
Method 3: I created a bootable rescue media and then rebooted off of the CD. When the app came up I attempted to use Active Drive Cleanser and ran into the same issue as Method 2... the software doesn't realize that my Intel SSD is actually an Intel SSD.
You may wish to file a report within Intel about the bug in Acronis's software. It should recognize that my Intel SSD 600p Series 256GB is really an Intel SSD. If this bug were fixed it would have saved me a couple hours of wasted effort.
badstink
None of the options that were provided here have worked (can't get my drive reformatted) and I have spent over 6 hours trying. I would like to close this community post and work directly with the Warranty Support team.
Santiago_A_Intel
You don’t need to open a new service ticket; we can help you out with any warranty issue, using the same support ticket already open.
You’ll be receiving a private message in order to proceed with the RMA.
Please wait for direct contact from Warranty team.
Have a nice day;
Santiago A.
