cancel
Showing results for
Search instead for
Did you mean:
GPT Drives
Esteemed Contributor III
I tried to clone my SSD using Intel's software, but it says that it does not work with GPT drives. Why not, GPT drives are the latest technology. I am using Windows 8 and there is no mention of Windows 8 on their tech support website. I am surprised that a company like Intel is not up with the latest technology. How do I clone my SSD from a GPT drive?
1 ACCEPTED SOLUTION
You might be able to do the cloning by using a third party data migration softwrae that supports GPT drives.
4 REPLIES 4
I just had this same issue trying to clone the HD in my new ASUS Q200e. This was my first encounter with a EFI Bios and GPT partitioning. I ended up using a freeware program called HDcloning which has full support for GPT partioning.
http://www.miray.de/products/sat.hdclone.html# freehttp:// http://www.miray.de/products/sat.hdclone.html# freehttp://
Note: I kept the GPT partition sizes the same instead of resizing on the new SSD drive.
I tried about 5 different cloning programs but none had the GPT support. I was getting very fustrated
until researching the EFI/GPT issue.
Message was edited by: Paul
If your hdd is either a Seagate or Western Digital, you can download the latest version of their migration softwrae which supports gpt and uefi. If not there are generic ones available with the required support.
I can recommend using the Farstone software "Total Backup Recovery 9 Workstation" which can be downloaded from Download.com. The Tool is easy to use and did the job for me without any problems.
