Community
cancel
Showing results for
Search instead for
Did you mean:
BKuij
Gelbe Led Blinkt > SSD 750 PCIe 400GB
Hallo,
der Gelbe Led von meinen SSD 750 Series 400 Gb blinkt dauerhaft. ( Karte ist erst 1Monat Jung)
Beim Starten im Bios ( UEFI) blinkt es nicht, aber wenn Windows denn startet ,
blinkt der Gelbe LED mal schneller und denn wieder langsamer dauernd
Der Lese / Schreib Geschwindigkeit ist OK.
Laut Intel SSD Toolbox ist der Aktuelle Firmware installiert
Im Bios sind die Einstellungen laut empfehlung Intel so gemacht
Was könnte hier der Ursache sein?
System:
Windows 10 64Bit.
Asus Z97-K USB 3.1
auf PCIE 3.0 x 16 ist der SSD gesteckt
auf PCIE 2.0 x16 ist Grafikkarte MSI GTX 760 gesteckt
Community Manager
Hello A3S3,
According to our translator system, one of the LED keeps blinking yellow and you would like to know why is that happening?
Could you please check the following http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-750-spec.pdf link, on page 33, it will show you the status of the lights, could you please let us know what is the LED number that keeps blinking?
We will be waiting for your response.
NC
BKuij
Hello NC,
thank you for the information.
The problem with the "yellow" LED has solved.
I have the SSD expanded and see there: What should be an AMBER LED is a YELLOW! LED !!!
Why this is yellow is probably a mistake in the production ?????
So, the Problem is Solved
Thanks and Greetings from Germany,
A3S3
Community Manager
Hello A3S3,
Thanks for replying back here.
Our guess is that the amber & yellow lights are similar (It is hard to determine, unless you have both on). Anyway, we are glad to hear the situation is fine.
Have a nice week and greetings.
NC
