Community
cancel
Showing results for
Search instead for
Did you mean:
DDeHa1
Getting Read Scan Error on new drive. Should I return, and try another drive?
Jump to solution
Got a new SSD drive (intel 545s 256gb) as a 2nd drive for my hyper-v VMs. Intel SSD Tool box says:
Read Scan Error: An error was detected reading data from the selected Intel SSD. Contact your reseller or local Intel representative for assistance.
No data on it yet. I swapped sata cables, and
same issue.
n_scott_pearson
Super User Retired Employee
If your dealer will not replace it, you can contact Intel Customer Support directly to arrange a replacement via RMA.
...S​
n_scott_pearson
...S​
DDeHa1
I've narrowed down the issue.
I only get the error when my SSD drive is plugged into the Intel SAS Raid (SATA mode) controller.
  • The SSD Drive is "INTEL SSDSC2KW256G8"
  • I have two storage controllers:
"Intel(R) C600 Series Chipset SAS RAID (SATA mode)"
Driver version: 4.3.0.1198
* Intel SSD Toolbox results:
"Read Scan: Error: An error was detected reading data from the selected Intel SSD. Contact your reseller or local Intel representative for assistance."
This error happens immediately at 0%. So it appears that the read scan doesn't even start.
"Intel(R) C600 series chipset SATA AHCI Controller"
* The Read Scan is successful when plugged into this controller.
I don't have any raid setup.
Any performance issue with just plugging it into the SATA AHCI Controller instead of the SAS RAID (SATA mode) controller?
DDeHa1
It seems having both of my SSD drives connected to the SATA AHCI controller performs better than my SAS RAID (SATA mode) controller, per my benchmarks below:
https://www.userbenchmark.com/UserRun/19780544
https://www.userbenchmark.com/UserRun/19780367
I'm going to leave the SSD drives connected to the AHCI controller, but I wonder if there's a way to get the same performance from SSD drives on the SAS RAID (SATA mode) controller? I guess if in the future I add another SSD drive, I'll probably either replace an existing SSD drive, or buy an additional SSD controller.
JosafathB_Intel
Hello DDeHa1,
Thank you for contacting Intel® Memory & Storage Support.
As we understand, you need assistance with your Intel® SSD 545s Series (256GB, 2.5in SATA 6Gb/s, 3D2, TLC) in your Dell* system. If we infer correctly we will appreciate if you can provide us with the following information:
• Your system configuration including manufacturer, model and part number of all your system components and a copy of the SSU (system support utility) logs this to have a better understanding of your current system configuration.
1- Go to https://downloadcenter.intel.com/download/25293/ and download the software.
2- When finished downloading it, open it.
3- Attach the file obtained to your reply.
• This issue seems related to your system configuration and compatibility between your system and the SSD, we advise you to check the list of compatible hardware from your OEM in order to discard any hardware compatibility issue. Based on the Intel® Product Compatibility Tool (http://compatibleproducts.intel.com/ProductDetails?activeModule=Memory%20and%20Storage#) your Dell system is not listed as validated, it does not mean that it does not work but unknown performance or issues may happen. Please take into consideration that this drive is a consumer SSD (Intel® Solid State Drives for Personal Use) and is not validated to be used in a datacenter/workstation environment.
• We advise you to open a ticket in parallel with Dell* to get further assistance regarding the latest drivers for your system and the recommended configuration.
We will be looking forward to your reply including this information.
Josh B.
A Contingent Worker at Intel
JosafathB_Intel
Hello DDeHa1,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your community thread remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
JosafathB_Intel
Hello DDeHa1,
Thank you for having contacted Intel® Technical Support.
I was reviewing your community post and we would like to know if you need further assistance or if we can close this community thread.
We will be looking forward to your reply.
Josh B.
