Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
436 Discussions
Good afternoon. The next question is, how is it possible to provide fault tolerance (RAID1) collect RAID array of P3700 nvme except on a software level?
AKata
Platform Supermico Ultra SuperServer 2028U-TN24R4T+,
Intel® Xeon® Processor E5-2695 v4 (45M Cache, 2.10 GHz)2pcs,
Supermicro Certified MEM-DR432L-SL02-LR24 Samsung 32GB DDR4-2400 LP ECC LRDIMM 18pcs,
Intel DC P3700 400GB NVMe PCIe 3.0 HET MLC 2.5" 20nm SSD 18pcs,
Intel DC P3700 800GB NVMe PCIe 3.0 HET MLC 2.5" 20nm SSD 6pcs.
Aleks3000,
According to the model of motherboard you provided, we can let you know that NVMe* drives are supported for RAID (0, 1, 5, 10), however, checking the motherboard's manual, we can see you may need to install the Intel® Rapid Storage Technology Enterprise NVMe.
What is the operating system you are going to install on it?
If you need to run RAID outside the operating system, then we do recommend to contact Supermicro* as it is not clear in the manual.
Let us know if you require any more assistance.
NC
Aleks3000,
NC
