Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
H410
nyonyo
I just bought a new computer with intel chipset H410 on the motherboard, the problem is, it only supports M.2 PCIe Gen3 x2, whereas all NVMe SSD around is PCIe gen3 x4, how could i solve this problem
n_scott_pearson
Super User Retired Employee
Well, that's a pretty crappy implementation. I wouldn't be satisfied with it. Can you return it?
Now, is there actually a problem? Or are you just concerned that there might be? In theory, with half the PCIe lanes, it should still work; you just get half the throughput.
Hope this helps,
