Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
HDDErase 3.3-4.0 and gParted Fail
I tried both versions of HDDErase on my (2)X25M-G2. Both sit at the blinking cursor screen and refuse to execute the task. I have two places to select RAID modes in my bios. When I enter the BIOS I choose integrated peripherals from the Main Menu. Now I have the option to choose RAID Mode. I can choose AHCI or IDE. Now further down in the integrated peripherals menu is the option to open another menu for the On Board Controller.In this menu I now have another RAID related setting. The options are RAID,IDE,and AHCI. I tried choosing AHCI for both, and booting up HDDErase. No luck. I tried IDE for both. No luck. So I started digging and digging through tons of articles and posts. I found info about using the hdparm command in gParted and Ubuntu. I tried the latest version of gParted. The command posted was hdparm --security-enhanced-erase NULL /dev/XXX where XXX is the drive identifier. In my case sda and sdb. I think that command was outdated as I refered to the help guide in gparted which more or less said the command was hdparm --security-erase-enhanced NULL /dev/XXX And still no luck. So I took it a step further. I read in some cases unplugging the SATA cable from the drives, powering up,boot to gParted, plug the drives in, refresh the drive list, then run the command will work. No such luck. I got an input/out error. I tried sudo hdparm --security-erase-enhanced NULL /dev/XXX and still get input/output error. I tried sudo hdparam -I which says the drive is now unlocked for 2 minuetes. Still I get the input out put error. gParted recognizes three partitions. The partitions for each 80GB drive, which are both unallocated, and a single 150 GB partition with ~70GB in use. With evrything else failing, I wonder, should I delete the 150GB Partition(not format just remove), apply that,and then try hdparm?
Oh and for the record I have a P55-GD65 mobo, running the drives in RAID0, with the latest firmware.
Community Manager
After hours of more digging I finally found http://partedmagic.com/doku.php Parted Magic and followed the tutorial http://blog.corsair.com/?p=4484 here. I checked my drive with smart defrag, and the analysis still shows it has insansley defraged. Is this normal? Does the app just not read the blocks correctley? Going to run HDTune in a moment to check my before and after scores.
DZand
Valued Contributor I
This is the procedure, which worked for me and my 2 Intel X-25M SSD's running in RAID0:
1. Make a complete backup of your RAID array and store it onto a hdd.
2. Create a bootable MS DOS medium (floppy, CD or USB stick) with HDDERase v3.3.
(HDDErase 4.0 doesn't work with Intel Postville SSD's)
3. Make sure, that your SSD's are connected with the first SATA ports (port0 and port1).
4. Enter the RAID ROM Utility (CTRL+I) and delete the RAID array.
4. Set the SATA Controllers of your SSD's to "IDE" or "Compatible" mode.
5. Disable the other SATA Controllers.
6. Boot off the DOS medium.
7. Run HDDErase.exe and do a secure erase with both SSD's one after the other.
8. While rebooting enter the BIOS and set the SATA Controllers to "RAID".again.
9. Enter the RAID ROM Utility and recreate the RAID array.
10. Reboot, enter the BIOS again and make sure, that the RAID is the first bootable hdd (Option "HARD DISK BOOT PRIORITY").
11. Recover your RAID backup by using the backup you have done at step 1.
12. Boot into your OS, which is on the RAID0 array.
EDIT: When I wrote my report about how I safely erased my SSD's running in RAID0 I forgot to mention, that I broke the RAID before starting the procedure and recreated it at the end.
Community Manager
Since using Parted Magic, do I really need to use HDDErase? Parted Magic offers the Secure Erase feature, and it even works with the disks still in RAID, so I just wonder if HDDE offers any benefit over PM? As I understand it, the principal of HDDE is that it uses the Secure Erase command. PM offers this, and many other features. So from what I can see they are the same thing are they not? My benchmarks were much better this time, and Random Access scores were better as well. Although typically, random access wise, the scores were not up by much. We are talking about a matter of dropping from 2 ms to 1 ms, which is still far ahead of all my mechanical drives.
As for the tips, thanks but I already tried all of that. I made sure to disconnect the sata cables on all my other drives to be safe to make sure there was no way to format them. I tried both ACHI and IDE using the guide https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase here. However when I got to step 3,Issue the ATA Secure Erase command, I got a permission denied error. So I tried it as sudo. Then it said sudo time was not a valid command. I tried to switch to superuser, although oddly the command prompt never changed from a $ to a # , but it still denied me permission.
DZand
There are some tools, which are able to do a secure erase of hdd's and SSD's, but AFAIK the only tools, which are recommended as being safe for the Intel "Postville" G2 SSD's, are the Intel Toolbox (doesn't work with RAID) and HDDErase 3.3.
Community Manager
So as long as the secure erase was issued,and did not brick my SSDs, then there is no need to get HDDErase working is there?
DZand
It is not easy to verify what happened to the SSD after doing a secure erase with any tool, which has not been approved for it.
Until now I always followed the advice of the technical experts and used just HDDErase 3.3 for doing a secure erase of my Intel X-25M SSD's ("Postville"),.
Community Manager
Well any idea how to get it working then? As I said, the tips you provided simply did not work. These were the exact steps I tried, with no avail sadly. And also you say HDDErase 4.0 is not compatible with the Postville SSDs, but I thought that was fixed with the latest firmware updatem or was that pertaining to a diffrent model? I know I saw mention of this here on the forums numerous times, but I do not recall a reference to a specific model.
DZand
It works, if you are doing the correct BIOS settings. Since each mainboard model has different BIOS setting options, it is not easy to let you know the special settings for your mainboard.
Although it was not always easy, I succeeded at least with the secure erase of my Intel SSD by using HDDErase 3.3 with different mainboards and even with a notebook.
Community Manager
Your step by step is useless with out one critical detail. From the Toolbox User Guide:
Secure Erase cannot be run on a bootable SSD or on an SSD with a partition.
DZand
This statement done by Intel is only valid for the Intel Toolbox, because this application can only be run from within Windows XP, Vista or Windows 7 and the OS wouldn't work anymore after the erasure of all data.
Contrary to the Intel Toolbox it is no problem to do a secure erase with the tool HDDErase on a bootable SSD containing the OS partition, because this tool only needs a DOS environment and it is very easy to create a bootable floppy, CD or USB with just the required DOS files and the file HDDERASE.EXE.
Since all data of all SSD partitions will be deleted after having done the secure erase, it is very important, that the user has done a complete backup of the SSD content before going to execute the HDDERASE.EXE.
Community Manager
Well after yet many many hours wasted trying to get hdderase working again, I give up! I am convinced the app will not work on my current PC. I suspect it has something to do with the SATA controller as I have searched and searched and tried every damn trick on the Internet...I tried disconnecting the power cable or data/sata cables and tried to boot hdderase. No luck. I deleted the RAID array, Deleted all the data off the disks. Set the discs to IDE mode and disabled the extra 7th SATA controller. Hell I even tried to boot an SSD off the 7th SATA port which is a Jmicron controller vs Intel Controller and still a big fail. I tried to launch Mini XP(Live copy of WinXP) and tried to install the SSD Toolbox but it failed because the .NET framework 2 was not installed. That wouldnt install due top limitations set for the OS. Tried to configure the settings myself, with no luck. It would be fantastic if Intel simply provided an official bootable no fus tool to secure erase our SSDs, but I doubt that will ever happen. Untill that day, I will stick with Parted Magic. Nice simple GUI, and it executes the Secure Erase command. It also offers Enhanced Secure Erase which claims to write a predetermined amount of data to the disk as stated by the SSD manufacturer. I can't comment on how well it follows any official specs from Intel but it executes Secure Erase with no fuss. What more can you ask for when HDDErase refuses to work? You know just as well as I do this forum is littered with probably a hundred or more threads with people trying to get HDDErase to work. Searching the Internet through google increases that to potentially thousands imo. There is no shortage of thread with people who simply can not get HDDErase working. I am truly disappointed in Intel lack of support on this matter. I do not mean my specific issue, but the major problems faced by users trying to use HDDErase in general.
