cancel
Showing results for
Search instead for
Did you mean:
HPE DL388 Gen9 with Intel DC S4600 480G*4 raid1+0
czhou7
New Contributor
4K read&write Whether the test results are normal or not?
2 REPLIES 2
Esteemed Contributor III
Hello ziling,
Thank you for your interest in the Intel® SSD DC S4600 Series. If you would like to know if an SSD is performing as expected, the corresponding benchmarking should be performed outside of a RAID, this because the setup (particularly in a RAID 1+0) alters the write and read values. Have you performed an individual benchmark and noticed any unexpected results? I'll be waiting for your response. Regards,Andres V.
Hello ziling,
I was wondering if you could check the previous message. In case you have any update or question, don't hesitate to contact us. Regards,Andres V.
