Community
cancel
Showing results for
Search instead for
Did you mean:
FBart4
Has there anybody an idea if INTEL DC P3600/3700 will work ink HP Z640 workstations?
The HP we are focused are 640 with one or two INTEL XEON E5-2620v3. The machines work with HP Zdrive which is a PCIe NVME SSD on PCIe2 Slot, but these SSDs are only available in 256 or 512 GB, which is not enough. We think that INTELS direkt I/O with XEON can make some programs faster.
jbenavides
Hello Frank_Barth_BMDE,
The Intel® Solid-State Drive Data Center Family for PCIe* are compliant with international IT standards. There are some requirements the computer must have in order to use them as data drives, or to boot from them.
We advise you to confirm with http://www8.hp.com/us/en/support.html HP support if your system meets the requirements to work with the Intel® Solid-State Drive Data Center Family for PCIe*, and to check for any compatibility implications with PCIe NVMe devices.
- PCIe* Gen3 x4 compatible connector (Form Factor: SFF-8639 or HHHL x4)
- UEFI* 2.3.1 or later
- Supported Operating System and NVMe driver.
*Additional configuration may be required to use these SSD's as boot drives.
For details, please check the http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3600-spec... Intel® Solid-State Drive P3600 Series – Product Specification and http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... Intel® Solid-State Drive P3700 Series – Product Specification.
Additional information may be located in the http://downloadmirror.intel.com/23929/eng/Intel%20SSD%20Data%20Center%20Family%20for%20PCIe%20Instal... Intel® Solid-State Drive Data Center Family for PCIe* P3700, P3600 and P3500 Series – Installation Guide.
