Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
309 Discussions
Hi, i like to clear it up about requirements for vroc bootable drive.. i have: ASUS x299 Mboard ASUS board.HYPER M.2 X16 PCI-E CARD VROC STANDARD key will be posible to make bootable drive using 2x samsung SM961 ?? Thank You..
Kgold1
Esteban_C_Intel1
Kgold1, Intel® VROC does support third party SSDs, the limitation is related to the Intel(R) X299 chipset on the motherboard mentioned. If you were using a different board with a different chipset the usage of third party SSDs would be available, there is a list of tested SSDs on that type of solution. This is the list, note this is not for your system but other boards that also support Intel(R) VROC: https://www.intel.com/content/www/us/en/support/articles/000030310/memory-and-storage/ssd-software.html Yes, you will be able to use the Intel(R) SSDs as boot drives with the setup mentioned, and the RAID levels supported would be 0/1/5/10 to boot from. (Windows 10* is the OS supported) Regards, Esteban C Intel Customer Support Technician Under Contract to Intel Corporation
Esteban_C_Intel1
Hello Kgold1, Thank you for contacting the Intel Communities. Since the system has an Intel(R) x299 chipset the answer would be the following: No. Intel VROC on X299 platforms supports Intel® SSDs only. You may reference to this article about Intel® VROC and the x299 chipset: https://www.intel.com/content/www/us/en/support/articles/000026106/memory-and-storage/ssd-software.html Thanks, Esteban C Intel Customer Support Technician Under Contract to Intel Corporation
Kgold1
Thank you for response. That really disappointing that Intel have so limited compatibility. Will Intel drives will be bootable on setup i mention before? will vroc standard key will work on intel drives to create bootable RAID-0?
Esteban_C_Intel1
