Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How can I update SSD under Linux
The firmware seems only have Windows version, how can I update that under Linux????
ZStan
Just burn the iso file (firmware) boot from cdrom.... its all the same which system you have
Community Manager
But there are only "iSSDFUT.exe" and "README.TXT", it can't be execute under Linux?
ZStan
For intel controller ssd (320, x25) there is just iso file, duno for 510 model which use marvel controller
Community Manager
Boot off the CD that you're created from the .iso firmware update file.
You're not suppose to run those .exe from under Linux.
Community Manager
Download and burn 0811036202M388208850.ISO as an image to a CD (or extract it and load it onto a bootable USB drive).
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363&keyword=solid+state+firmware&la... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363&keyword=solid+state+firmware&la...
There is a basic OS included with the image that will load to allow the update.
