Community
cancel
Showing results for
Search instead for
Did you mean:
JBoyc1
How can I updated ssd firmware via serial console?
Jump to solution
I have an Intel 525 Series mSata 60GB SSD that I recently purchased used. It is installed in a new PC Engines APU2C4 box that only has a serial console connection to a terminal window; no GUI. There is no operation system installed yet; it will be pfSense. I would like to be able to check what firmware is currently on the SSD, and update it if necessary. However, the Firmware Updater Tool is GUI based and doesn't appear to work via the serial console. Is there another option for updating my SSD firmware via a serial console command line? This is the only hardware that I have with an mSata slot, so I don't have an option to move it elsewhere to do the update.
Jeff
Tags (1)
Community Manager
Hi Jeff,
We understand that you are having troubles updating the Firmware for your Intel® SSD 525 Series via Intel® SSD Firmware Update Tool. We would be more than glad to assist you.
We would like to inform you that for the Intel® SSD 525 Series there are no firmware updates available:
- https://www.intel.com/content/www/us/en/support/memory-and-storage/000017245.html Firmware Versions for Intel® Solid State Drives and Intel® Optane™ Memory
Please let us know is there something else we can help you with.
Junior M.
Community Manager
Hi Jeff,
Junior M.
JBoyc1
Ok, I want to make sure that I clearly understand your statement that there are no firmware updates available. Is this to mean that since the 525 Series SSD was put into production, there has never been a firmware update for it? I see in the documentation that this SSD was initially released in December 2012, with an engineering revision in March 2013. The official launch date is Q1 2013, and the product page does not state that it is end-of-life'd yet http://ark.intel.com/products/series/71178/Intel-SSD-525-Series Intel® SSD 525 Series Product Specifications. So I just want to make sure that I understand that there has never been a firmware update for the SSD 525 Series product line, and I am specifically interested in the 60GB version. Thanks.
Jeff
Community Manager
Hi Jeff,
That is correct, there is only one firmware version for this SSD that is LLLi. We only release new firmware version if it is required to address a bug or issue.
Also, you can check that on the https://downloadmirror.intel.com/26491/eng/Intel_SSD_Firmware_Update_Tool_2_2_2_Release_Notes_018.pd... Firmware Update Tool Release notes there is no firmware updates information associated with your Intel® SSD 525 Series.
Junior M.
JBoyc1
Thanks for the confirmation. I was also able to confirm that the product label on my SSD has printed on it that the firmware is LLLi. So no need for me to try to figure out how to update it. Thanks.
Jeff
Community Manager
Hi Jeff,
We are glad to hear this information was useful for you.
Please contact us again if you need further assistance.
Junior M.
