Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
How does one erase optane 905P SSDs?
TRive1
Ordinary SSDs can be securely erased using a bootable Parted Magic USB stick. Does this procedure apply to 905Ps, or is there another procedure?
Hello tseax,
Thanks for posting your question in the Intel® SSD community.
In the following link you will find the procedure to perform a secure erase:
https://www.intel.com/content/www/us/en/support/articles/000022179/memory-and-storage.html https://www.intel.com/content/www/us/en/support/articles/000022179/memory-and-storage.html
You can use the following commands:
  • List disk: Displays the list of attached disks and USB flash drives
  • Sel disk (select disk): Selects the scope to work in
  • Clean all: Removes partition and volume information from the selected device
Remember you cannot perform a secure erase in the primary SSD while it is running.
Hope this information helps you, if you have any additional question let me know.
Juan N.
TRive1
Thank you for the reply Juan N.
I should have specified, Parted Magic is a bootable tool used to erase a system SSD in preparation for OS reinstallation. It is a similar offline bootable tool (perhaps Parted Magic would suffice, I don't know as yet) that I'm looking for. The 905P will be the system disk. Parted Magic normally takes only seconds to wipe a conventional flash memory drive. I'm wondering whether the same procedure is safe for, or applicable to, the 905P line.
Hello tseax,
Thanks for the clarification.
The 905P is a regular SSD from the software point of view. After checking the available information in the PartedMagic website it does not show any support for a PCIe or U.2 storage. It would be recommended for you to ask PartedMagic directly about their support for this kind of SSDs.
Juan N.
Hello tseax,
I would like to know if you have any additional question regarding this issue?
Juan N.
TRive1
Thanks Juan. I have no further issues.
Hello tseax,
I have done additional research on your issue and I found the following article that shows additional ways to do a secure erase on an Intel SSD.
https://www.intel.com/content/www/us/en/support/articles/000006011/memory-and-storage.html
This are the additional validated ways to do a secure erase.
Hope this information helps you.
If you have any additional question feel free to open a new thread. We will be glad to help you.
Juan N.
Hi all,
I just want to add the it's possible to secure erase NVMe* drives using the Intel SSD Toolbox.
Diego V.
