Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
How to Replace RAID1 HDD with SDD
KLoh1
I have a computer that has two HDD's in RAID1 configuration that is manged somehow by the Intel Matrix Storage Manager. Came that way from Dell. I want to replace them with SSD's. How do I do that and retain the RAID configuration?
Jose_H_Intel1
You will need to use a data migration or cloning software that supports RAID volumes. Unfortunately I am unable to provide any specific recommendation but you may search online for a tool that will suit your needs.
Please also note that TRIM may not be supported through RAID.
