Community
cancel
Showing results for
Search instead for
Did you mean:
ASout1
How to clean install Win 7 OS on SSD 535
After connecting the SSD 535 to the computer can you then install OS using disks from manufacturer? Once that is done then change the bios? Then restart?
Or is there a different sequence?
Tags (1)
jbenavides
Hello H2R2,
The process to install the OS to your Intel® SSD 535 Series should be the same process used for other hard drives.
Once the new SSD is connected to the PC and properly detected in the BIOS you can boot from the OS installation media, proceed to install the OS and once the installation is complete, you should be able to boot from your new SSD. As you suggested, this may include changing the boot order in the BIOS during the process.
