Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
How to force X25-M in SATA150 mode
I try to use a X25-M 120Gb on a VIA EPIA SP13000 but the BIOS doesn't recognize the SSD.
After reading some forums I see there is a known issue with the chipset VT8237 and SATA II. The mode negotiation doesn't work.
To solve the problem the disk must be locked in SATA 150Mb/s mode.
How can I do that on the X25-M as there is no external jumper to set it ?
Thank you for your help.
DocRacing
Tags (2)
Community Manager
Unfortunately, you cannot..... Can you install a PCI SATA controller?
