Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
How to force X25-M in SATA150 mode
Community Manager
I try to use a X25-M 120Gb on a VIA EPIA SP13000 but the BIOS doesn't recognize the SSD.
After reading some forums I see there is a known issue with the chipset VT8237 and SATA II. The mode negotiation doesn't work.
To solve the problem the disk must be locked in SATA 150Mb/s mode.
How can I do that on the X25-M as there is no external jumper to set it ?
Thank you for your help.
DocRacing
Community Manager
Unfortunately, you cannot..... Can you install a PCI SATA controller?
