Community
cancel
Showing results for
Search instead for
Did you mean:
YLin34
How to get out of "disable logical mode"?
I have a P4600 SSD in my Ubuntu PC. It went dead just about 1 hour ago, as I can't perform any read/write. I notice the LEDs are in solid RED and solid AMBER. I can't find product spec for P4600. But for P3600, solid RED means it's in "disable logical mode". How do I fix this issue?
It's OK if any repair wipes out my data. I just want to get the drive back to a working state.
Community Manager
Hello yaolin,
Thanks for being part of our community. We understand your Intel® SSD P4600 Series is showing a solid red LED and data can't be read/written.
Just for testing, can you move the SSD to a different PCIe slot or install it on a different system altogether?
Also, is the drive visible by the OS in any way? We recommend to check the drive status using https://downloadcenter.intel.com/download/27497/Intel-SSD-Data-Center-Tool?product=87278 Intel® SSD Data Center Tool.
Eugenio F.
YLin34
I tried the SSD in 3 different PCs and it shows issues in all of them.
Ubuntu 17.10: lspci shows the device correctly. But can't read/write. LEDs in solid red and amber.
Windows 8 and Windows 10: Device Manager shows it's a Standard NVM Express Controller, but reports "This device cannot start (Code 10)". LEDs in solid red and green.
Then I tried your SSD Data Center Tool. "isdct show -intelssd" shows: No results.
Community Manager
Hello yaolin,
Thanks for your answer.
At this point, the best option is to https://www.intel.com/content/www/us/en/support/contact-support.html contact your local technical support for further assistance.
Please check your private messages.
Eugenio F.
