Community
cancel
Showing results for
Search instead for
Did you mean:
TRott1
How to re-enable SSD in 'disable logical state'
due to a small mishap (hot-unplug of a card while server was still powered) one of my P3500's has gone into "disable logical state".
The card itself gets detected fine but I cant access the VM datastore on it. I have moved the drive to a Windows box and can run isdct on it but all I get is the disabled state.
Can you please let me know how to re-enable the drive.
Let me know what additional info you need.
Community Manager
Hello TR_1234,
We understand you have an Intel® SSD DC P3500 Series that is reporting a "disable logical state" error.
We regret to inform you that this error is considered a "catastrophic failure", we do not have any troubleshooting available to re-enable your drive. Our main recommendation will be to http://www.intel.com/content/www/us/en/support/contact-support.html contact support in order to initiate a warranty replacement ticket, so long as the drive is still within warranty.
As far as data recovery goes, we cannot make any guarantees. You would need to contact a data recovery specialist in your area for pricing, services, and terms.
- http://www.intel.com/content/www/us/en/support/solid-state-drives/legacy-consumer-ssds/000006357.htm... Data Recovery Options for Intel® SSDs (USA Based).
Carlos A.
