Community
cancel
Showing results for
Search instead for
Did you mean:
CBoya1
How to reconfigure RAID 1 array after installing new SSD
Jump to solution
My system had an existing RAID 1 array with 2 identical SATA drives under Windows 8.1 using an ASUS Sabertooth Z77 motherboard. This was the only storage and was the primary boot drive for my system.
I then installed a new SSD as the system drive, chose this as the primary boot device, and performed a new installation of Windows 8.1 on this drive. On boot, the BIOS loaded Intel RAID software recognises the SSD as a non RAID device and the old array shows with a status of rebuild if I enter the configuration management via CTRL-I during boot.
I want this array to appear as the secondary storage on my reconfigured machine. How do I set this up so that the array is recognised and in the correct status without losing all the data. I have tried to install the Intel Rapid Storage Technology software via the SetupRST.exe but the installation fails with what appears to be a timeout error in the log.
I have also downloaded the x64 files but I don't know how to install these directly.
Thanks in advance for your help and suggestions.
Silvia_L_Intel1
Hello Col1965, from what I understand from your post is that you want to boot to Windows 8.1 from your SSD and you want to keep the RAID 1 as storage. If this is correct it will be necessary to set the SSD as your first boot drive on BIOS.
Regarding the RAID, there are two options:
Option 1: Manually delete the Windows installation files from the RAID. Bear in mind that some registry file cannot be removed completely, so there are going to remain on the array.
Option 2: Back up all data from the RAID and format it. Then create a new Raid array from scratch.
Silvia_L_Intel1
CBoya1
Hi silvia_intel, I have my system booting from the new SSD so that part is working fine.
I'm happy to go with Option 1 that you mentioned (at least for now) but the RAID array is showing a status of REBUILD. From what I have read, this means that the array needs to be rebuilt from the operating system but I don't know whether I need to trigger this manually or whether it will happen automatically.
Is there anything I need to do?
CBoya1
After leaving the computer running for a day, the status has now returned to normal so I guess the RAID array was being rebuilt in the background.
Thanks for your help and insights.
Silvia_L_Intel1
You are welcome Col1965.
