Community
cancel
Showing results for
Search instead for
Did you mean:
SLiu60
How to upgrade P3600 SSD firmware in VMware ESXi
Dear All,
I had some P3600 NVME SSD which were installed in DELL R730XD server,and they are running VMware vSAN 6.2 on it. The default firmware version is DP01,and VMware suggest us to upgrade the firmware to DP04。
Anyone know how to do the NVME SSD firmware upgrade work in ESXi6.0 U2? In Intel Website, I also can not find the firmware package and download link of ESXi version .
SSD Info:
/opt/intel/isdct] ./isdct show -intelssd
- Intel SSD DC P3600 Series CVMD6250009B2P0EGN -
Bootloader : 8B1B012F
DevicePath : intel-nvme0
DeviceStatus : Healthy
Firmware : 8DV1DP01
FirmwareUpdateAvailable : Please contact your Intel representative about firmwar e update for this drive.
Index : 0
ModelNumber : INTEL SSDPEDME020T4D HHHL NVMe 2000GB
ProductFamily : Intel SSD DC P3600 Series
SerialNumber : CVMD6250009B2P0EGN
- Intel SSD DC P3600 Series CVMD626600GU2P0EGN -
DevicePath : intel-nvme1
Firmware : 8DV1DP01
Index : 1
SerialNumber : CVMD626600GU2P0EGN
Community Manager
Hi SnLiu,
We understand that you want to upgrade the firmware for the Intel® SSD DC P3600 Series.
We want to inform you that the firmware version you are requesting is an old one, we always recommend to install the latest one. In this case is 8DV101H0 with Bootloader 8B1B0133 as per this https://www.intel.com/content/www/us/en/support/articles/000017245/memory-and-storage.html article.
Since you already have the Intel® SSD Data Center Tool please follow the next commands:
isdct load -intelssd (index of the SSD)
Please let us know if that works.
Junior M.
SLiu60
Our system is VMware esxi, I didn't find any package can install in esxi 。
Community Manager
Hi SnLiu,
Thanks for the reply.
Here is the latest version of the Ihttps://downloadcenter.intel.com/download/27144/Intel-SSD-Data-Center-Tool?product=87278 ntel® SSD Data Center Tool for VMware*.
In order for you to update the firmware you just need to enter the following command:
Junior M.
SLiu60
I know that tool and I already install on my machine, the question is I can not find the install package for the firmware upgrade.
Finally, I ask DELL support to get the solution for that,the solution is not good, but better than nothing.
Community Manager
Hi SnLiu,
Thanks for the update.
Based on the information we found, it seems that the Firmware 8DV1DP01 is an OEM version and belongs to Dell*, reason why the Intel® SSD Data Center Tool does not detect any install package.
The Firmware 8DV101H0 is for retail versions of the SSD. In this case, we suggest you contact Dell* in order to verify if there is a firmware available for the SSD.
Junior M.
