Community
cancel
Showing results for
Search instead for
Did you mean:
DKumm
How to use the Intel SSD 6 in a HP Pavilion equipped with the m.2 buss - the solution!
Jump to solution
My HP Pavilion - 590 -p0069 has an AMD processor and motherboard with an m.2 slot. In order to recognize the Intel SSD 6 mounted in that slot I took the following steps:
F10 into the AMD bios setup / select Security/ select Drives/ and select "disable" m.2 option. Sounds counter-intuitive but it works.
Use Intel SSD Toolbox to confirm it's presence. Use Intel Data Migration to clone the operating system (Windows 10 in my case) to the SSD and change the boot order. Works just great.
DKumm
For the Intel 660p 1TB 3D NAND QLC M.2 2280 PCIe NVMe 3.0 x4 Internal Solid State Drive
on sale at my local Microcenter for $105.
AlHill
Have you run any performance test?
Doc
DKumm
