I am facing very frequent disk boot failure problem with my PC of Pentium II mother board. Even when I change the hard drive after a few days again I facing the problem of disk failure. I would like to know the compatible Hard drive (PATA) for my Pentium II model mother board system from the all available PATA hard disks. The details of the mother board are given: Pentium-II-MMX; CPU-333 MHz; Cache-512Kb; i 440 LX-W977TF-2A69JP8EC. Kindly suggest the compatible hard drive (PATA) from the availble different specification like: speed of the hard disk, size, memory capacity, etc. Thanking you
Did you check the jumper setting and the cables? The data and/or power cables may be causing the issue.
