cancel
Showing results for
Search instead for
Did you mean:
I am having trouble with my intel 660 2 TB m.2. I initially formatted it and if worked just fine, but in the past week or two I can't seem to find it anywhere but in bios. I have tried updating drivers and everything else that I could.
BGrif9
New Contributor II
imageimageimageimageI got this m.2 about a month ago and it has worked fine until recently. I have uninstalled and reinstalled the drive i have looked thorough disk management and it dose not seem to appear anywhere in windows but it dose seem to show up in bios.
9 REPLIES 9
LeonWaksman
Contributor II
Did you try to check with Intel SSD ToolBox Utility? https://downloadcenter.intel.com/download/29205/Intel-Solid-State-Drive-Toolbox
Leon
BGrif9
New Contributor II
Yes and sadly it only seems to pick up my other drives. The Intel one dose not appear here.image
LeonWaksman
Contributor II
  1. Since the drive is recognized in Bios, but not in Windows, probably failed. You may request a replace it. Check your Warranty coverage here: https://supporttickets.intel.com/warrantyinfo?lang=en-US
  2. You may also see if you can find your drive using diskpart utility:
  3. Click on Windows + R keys and run diskpart command. Command Prompt window should open.
  4. In the prompt write list disk and click on enter. You should see list of all recognized drives.
Leon
BGrif9
New Contributor II
So I figured it out but it's quite anticlimactic. It was a driver update. Now I tried this same update on atleast 5 separate occasions but it always said I had the most up to date driver. Now I do it and suddenly within 3 seconds I can view and acsess my m.2 like nothing was ever wrong with it.
