Community
cancel
Showing results for
Search instead for
Did you mean:
tnguy81
I can't install win 7 on intel ssd 600 seri
I can not start hard drive . I can not find intel rapid for it. wish everyone helped me
thanks everyone
Community Manager
Hello tuyennguyen1703,
Thanks for posting. The Intel® SSD 600p uses NVMe technology. However, Windows 7* doesn't natively NVMe support and that's why it can't detect the drive.
There's a way to add the required drivers for the installation, please refer to the following guide for instructions:
https://www.intel.com/content/www/us/en/support/articles/000023002/memory-and-storage.html Windows* Installation Guide for Intel® Solid State Drive 6 Series for PCIe* with NVMe
On page 9 of the guide, you'll find two different installation methods. Please review each one to learn which applies to your situation.
Please let us know if there's anything else we can do for you.
Eugenio F.
tnguy81
I have to connect to the PCIe slot correctly .I am currently connected through slot M2
tnguy81
I use Win7 USB3.0 Creator it runs very long .. I wait few hours is not finished
Community Manager
Thanks for your reply. If you're having difficulties creating the image with the USB 3.0 driver, please make sure you use a fresh Windows 7* image:
https://www.microsoft.com/en-us/software-download/windows7 Download Windows 7* Disc Images (ISO)
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Eugenio F.
Community Manager
We haven't heard from you in the last few days. Please let us know if there's anything else we can do for you.
Eugenio F.
tnguy81
Hi Eugenio F
I can not install the operating system because it does not get nvme . I tried the tutorial but can not
https://www.intel.vn/content/www/vn/vi/support/articles/000023888/memory-and-storage.html How to Install Microsoft Windows* 7 on a PCIe* NVMe Intel® SSD
Thank U
Community Manager
Thanks for your reply. We've tested this workaround extensively and several customers have confirmed this worked for them. Can you describe step by step the process you're following and where/how is it failing?
Eugenio F.
tnguy81
I try create usb boot win 3.0 but it is very slow . I create win mini PE..After I extrack file win7.iso and I setting..Next step I load driver nvme but can not. You look picture 2 and 3 on post 1
Community Manager
If you're having issues with installation method 2, please test method 1 instead.
Eugenio F.
