Community
cancel
Showing results for
Search instead for
Did you mean:
JMcCo11
I have a desktop with a 2TB harddrive in 2 partitions C &D When I clone it to my SSD it copies both partitions. I only want the C drive and leave the D drive where it is. How can I do this??
I have a desk to with a 2TB hard drive in 2 partitions C & D. When I clone it to my SSD it copies both partitions. I only want the C partition and leave the D partition on the hard drive. Can I do this and if so how??
Kevin_M_Intel
Hello Michael_1933,
Please note that if you are using the Intel® Data Migration software from our side it basically will clone all information from one disk to the other one including partitions but the option to select specific information is not available.
You can try with a third party software with that can provide this feature. Here is one as an example:
http://www.partitionwizard.com/ http://www.partitionwizard.com/
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Kevin M
