cancel
Showing results for
Search instead for
Did you mean:
I think my G2 is failing, can I do anything to test it?
Esteemed Contributor III
My G2 worked fine for about a week. Now I am experiencing the following:
When the pc boots in bios I get a "disk read error" if this does not happen it hangs before fully booting into the OS, or sometimes it will boot but then it hangs. Either a complete freeze, or a complete freeze but the mouse still moves. When I reboot the system it occasionally runs chkdsk and it comes up with orhaned files. I've ran SMART and it says the disk is ok, but now I've taken the G2 out the system its working ok, so I don't think it can be anything else but the G2.
Any suggestions on what I can check/ test before it goes back under rma?
0 REPLIES 0
