Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
INTEL 330 SSD COMPATABILITY WITH SATA 1.5?
Community Manager
Hello all --------
Will the Intel 330 6.0 sata work with a mama board that is only a sata 1.5? It is an older board. thanks
You can contact me directly at dew PERIOD drop PERIOD inn @ sbcglobal DOT net.
UHans
New Contributor II
Yes, the 330 series drives are backwards compatible with SATA I, Aka SATA 1.5Gbit/s. There are a couple of threads here and in other forums where people are describing a links speed negotiation bug when connected to the older Nvidia MCP79 chipset (that should connect as SATA II / 3Gbit/s, but instead connects at SATA I / 1.5Gbit/s). That bug is not relevant to you, but it proves that the drive can operate at 1.5Gbit/s
UHans
New Contributor II
References:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167122 http://www.newegg.com/Product/Product.aspx?Item=N82E16820167122 (Click Feedback tab and search for "nVidia MCP79")
/thread/28764 http://communities.intel.com/thread/28764 (The thread is about the 520 drives, but they use the same controller)
Community Manager
Does not work with my KX18DS-ProII(nforce2 SPP + nforce2 MCP RAID), 320 SSD works fine however(2x RAID0), Vertex3 does not work also, so it is probably SandForce controller issue.
Also does not work in FS Amilo a1667g/a3667g (VIA K8T890 + VT8237R) cause of the bug in VT8237R, probably can be replaced with VT8237R Plus, which fixes SATA negotiation bug.
