Community
cancel
Showing results for
Search instead for
Did you mean:
lsund1
INTEL SSD 320 SERIE 160 GB. After 3 weeks of error searching, I found an article about errors where ssd is only showing 8mb. This harddisk has been used, but is suddenly showing nothing but the 8 mb.
Jump to solution
Is there anyway, i can save my data on this disk being used on a macpro
DiegoV_Intel
Hi lsund1, Thank you for posting in the Intel® communities. As you mentioned, the 8MB issue has been reported before and currently there is a fix for it by updating the firmware, however the fix should be applied before the issue itself happens. At this point, your drive is not recoverable so I recommend you to contact Warranty Support to get further options for you: https://www.intel.com/content/www/us/en/support/contact-support.html#@3 Unfortunately, considering the current status of the drive, the data stored in it cannot be recoverable. Have a nice day. Regards, Diego V. Intel Customer Support Technician Under Contract to Intel Corporation
DiegoV_Intel
