Community
cancel
Showing results for
Search instead for
Did you mean:
mmer
INTEL SSDPEKKW010T7 - smart error?
Jump to solution
hi
i bought an Intel M.2 600p with 1TB just a couple of days ago.
On there i got my debian system, with an encrypted /home.
Right now smartctl is telling me, that the health self-assessment test failed:
SMART overall-health self-assessment test result: FAILED!
- available spare has fallen below threshold
SMART/Health Information (NVMe Log 0x02, NSID 0x1)
Critical Warning: 0x01
Temperature: 29 Celsius
Available Spare: 9%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Read: 4,020,000 [2.05 TB]
Data Units Written: 1,224,368 [626 GB]
Host Read Commands: 26,920,285
Host Write Commands: 23,527,124
Controller Busy Time: 154
Power Cycles: 16
Power On Hours: 197
Unsafe Shutdowns: 2
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 1
Critical Comp. Temperature Time: 0
That does either mean:
- the ssd has already used spare space and is about to fail - after a mere 626GB written(!!!)
- the smartctl shows bugged stuff?
- the firmware is STILL not working properly on linux (i read alot on data corruption with the original firmware ...)
can someone from intel answer this?
i'm still able to return this ssd, since it's only a few days old.
cheers
Community Manager
Hello mer81at,
We understand that the SMART values for your Intel® SSD 600p (1TB) show the drive has consumed all of its available reserve space.
The drive should't go through its available reserve space after such a low amount of data written on it. We recommend installing the drive on a different system to confirm if you get the same results.
If possible, please test it on a Windows 10* PC to compare it with the SMART details pulled by https://downloadcenter.intel.com/download/27330/Intel-Solid-State-Drive-Toolbox Intel® SSD Toolbox.
If you get the same results, we recommend reaching your reseller to request a replacement.
Eugenio F.
Community Manager
Hello mer81at,
Eugenio F.
mmer
thanks for the honest answer
after the data corruption issue with the first firmware on linux
and obviously fragile hardware, my confidence in intel ssds is gone (especially when using in linux, you do not even provide a ssd toolkit for linux ... )
i'll send it back and replace it with a samsung, as all my 3 year old samsung 830s work flawlessly since day1 on debian!
