cancel
Showing results for
Search instead for
Did you mean:
ISM and RTS question
Esteemed Contributor III
OK, got a question that I am having a really hard time finding.
I do get a lot of returns on RTS and TRIM, but nothing on this question.
So for a while I have been really used to IMS (Intel Matrix Storage). Now that RTS has downloads out for what is replacing IMS my question is this.
Do I uninstall IMS Reboot
and
Install RTS = Thats it?
Also the latest version I have is
9.5.7.1002 ..........Anything newer?
I wouldnt keep both since they both do the same thing right?
Specs
Rampage II Extreme (Intel Chipset)
2 Intell SSD's G2 80GB
2 HDD RAID 0
Thanks for all the expert help!
John
1 ACCEPTED SOLUTION
DZand
Contributor III
and
Here are my answers:
1. You can install the IRST package without any problems. The IMSM software will be uninstalled automaticly.
2. The latest IRST version is 9.5.7.1002.
3. It is impossibe to run both IRST and IMSM simultaneously, because I are doing the same job (but another way).
28 REPLIES 28
Hi Fernando,
Out of interest, where did you see mention of TRIM with (future) 9.6.x RST?
Cheers.
DZand
Contributor III
Look into the first post of this thread: /message/86930# 86930 http://communities.intel.com/message/86930# 86930
Fernando
I use that old standard msahci driver and get WEI score of 7.7, a score that has been consistent, never got below that since TRIM firmware installed.
"b) the use of the Optimizer (=part of Intel's SSD Toolbox) has the same or maybe even a better effect than the automatic Trim command support by the generic MS IDE/AHCI drivers."
Now, Fernando, how is it possible for running TRIM via Optimizer better than automatic TRIM??? If anything, I see TRIM running automatically as the best way to go.
