cancel
Showing results for
Search instead for
Did you mean:
Identify a SSD Device
Esteemed Contributor III
Hi i bought an Intel SSD Device and im having troubles identifying it.
The Packeg of the SSD says it is an itel 320 series
The Bill of the seller tells me its a x25-v sata 2 ssd
The Sticker on the SSD Package tells me its Product Code is SSDSA2CW120G3K5
My Bios shows me the SSD as SSDSA2CW120G3
To my knowladge the x25 and 320 are two totally different serieses. And I would like to know which this ting really is.
Spcially I would like to know If it supports hardware aes encryption since this is the reason i bought it.
Is there any Way of determing which drive this exactly is and if it is using aes encryption
The other Qestion is how do i enable the aes encryption on en 320 series
Looking forward hearing from you,
nobody
1 REPLY 1
mmokk
Contributor
the 'g3' from the product code and bios means the drive is a 320. the bill from the seller is incorrect.
