Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel 320 80GB SSD 8MB Bug
Jump to solution
Hi there,
I got an Intel 320 and copied my system with Acronis Disk Director on it, reboot and Windows 8 booted fine. After Login (30 seconds) the System crashed and displayed "critical_process_died".
On a reboot there is no data to boot on disk.
So I switched to the BIOS, the SSD is displayed with BAD_CTX 0x ....
I booted Linux and searched for information, i found this link, wrote it to CD and tried...
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 Download Center
It just displays that the update of the drive does not success and I may try to disable password, enable SMART or switch to IDE legacy mode. The third one is the only one on my (latest version) BIOS which is possible.
So I switched to SATA "IDE Mode" and retried, with no success. The same message displayed as on the first try.
So I switched to Intel Support and selected my product ... which results in "Keine Ergebnisse gefunden für Solid-State-Laufwerke und Caching + Intel® Hochleistungs-Solid-State-Laufwerk + Intel® 320er-Solid-State-Laufwerke (80 GB, 2,5"/6,35 cm, 3-Gbit/s-SATA, 25-nm-Technik, MLC)" ... means no result found.
http://downloadcenter.intel.com/SearchResult.aspx?lang=DEU&ProductFamily=Solid-State-Laufwerke+und+C... Download-Center
Where do I find the latest firmware for my device which enables it again?
Ruben
Tags (1)
Accepted Solutions
Highlighted
It is good to know you already contacted your local Intel support team. In this scenario the solution is to replace the drive as it is beyond repair through a firmware update.
Community Manager
The firmware to repair your SSD's problem is part of the bootable tool you tried to use, but failed, apparently.
If you have another Windows PC you can use with your 320, you can try to update the firmware with the SSD Toolbox:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3349&DwnldID=18455&ProductFamily=Solid... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3349&DwnldID=18455&ProductFamily=Solid...
The SSD Toolbox, and the bootable firmware update tool you tried to use are the only method of updating your SSD's firmware.
If both of the methods do not work, you should contact Intel support:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Highlighted
Community Manager
I tried both tools on two computers. With Legacy IDE and SATA Mode, all failed.
Thanks for your hint with the support.
Ruben
Highlighted
Community Manager
I've send a Mail to the Support with the Serialnumber and the displayed serialnumber BAD_CTX 00000136.
Btw: Intel Toolbox Update fail with the errormessage:
"Error: SMART enable failed while attempting a firmware update. Reboot and try again. If error persists, use the Intel Firmware Update Tool located at:"
Hope they may help me.
Highlighted
Highlighted
Community Manager
2 Mails later I got a response from the support how may I send a package via dhl with my SSD-Drive.
Great!
Best regards
Ruben
Highlighted
Had the same issue - "Enable SMART" when attempting to apply new firmware (via SSD toolbox and with CD).
What worked is that in SSD Toolbox (you need a working Windows machine for that) I first erased the drive. After that Firmware update went without a glitch.
What I read this error anyway did not allow data recovery, so this is not a concern.
