Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel 320 SSD and windows XP Embedded
Hi.
We are trying to use a SSD with a computer running XPE on a high end CNC machine. At the moment we are running a compact flash and finding the ATOM is struggling for speed with Read/Write. We installed our image on a 40Gb intel 320 disk and it would not boot. Would get to the windows splash screen and re-boot constantly. From our experience normally means a corrupt file. We installed a std XP image and would run fine, so seems to be Embedded related. (We re-installed the XPE Image on a CF and normal Disk to check the image and they both worked fine)
Will the drive run on XPE? Do we need to add a file or driver to the image to get it working? If anyone has any experience your input would be much appreciated. Thanks.
Tags (1)
